WiFi/LTE antenna BDM-2
200 posts in this topic
7 hours ago, Argos said:
Hello!
 V  is isolated from the rest or does it not matter?
,,,not...!!!
On 8/19/2021 at 10:47 PM, Admin said:
Юрий 26,,, the dimensions in red are for you...
Hi Admin,
How much the gain has the antenna in red? is it 1800-2100 MHz? Thank you.
On 1/10/2021 at 0:51 PM, miloudsatdz said:
thank you ADMIN
I made an antenna according to this design and the result was very positive even though I used a 75 ohm cable
Tested on 3G and 4G network
The result in the photo is attached
Hi, does this work on 1800-2100 MHz (B3 & B1) frequency? Thank you!
Edited by alsamman80
alsamman80
It is designed for 1800 frequency only
On 12/21/2020 at 10:05 AM, Admin said:
,,, for the 1.8 GHz band, other dimensions are needed...!!!
Hi Admin,
Could you recalculate this antenna for 75 ohm cable? Thank you!
thank you ADMIN
Hi, does this recalculated or design specially for 75 ohm cable? how much is the gain? Thank you.
,,,the gain it"s aprox 15dBi...you can try whith 75 Ohm cable impedance...!!!
alsamman80
sorry, I don't have antenna simulator software
,,,yes, respecting the positioning of the ports as in the image below...
20 hours ago, DavidER said:
Will it work on 2 ports with a 75 ohm cable?
yes it work  on 2 ports with a 75 ohm cable
hi admin i want to make an antena for 1800 MHz. what is the best option? which antena can best signal speed 1800 vs 900 ?. thank you
I think you can try a Bester antenna from this post.
On 1/10/2021 at 3:21 PM, miloudsatdz said:
thank you ADMIN
is this use one cable?? or two cables??
,,, two cables at 120 degrees can also be used...!!!
24 minutes ago, GiangVN777 said:
Does it work on 6ghz frequency?
,,, yes, it is possible, but with other dimensions...!!!
How can you simulate these suitable for 2.4ghz frequency
Do you use software for calculations?
,,okay, I will try...!!!
I use cst.
,,,this it"s okay...???
,,,this is almost real...
,,,and these dimensions are updated...
