WiFi/LTE antenna BDM-2
200 posts in this topic
,,,mitiche...please tell me how you posted the images above...!!!???
make sure there's GOOD electric contact between inner wire and Excited Disc (that White looks like polyester resin or some dielectric paint)
withe antennaScreenshot-20260104-234539-2.jpg without antenna
hello sir i didn't get a good result its the same result with or without antenna
im using the 1800 model and i think my aria is using band 40
can i make changes to the antenna to get a batter result or maybe im bot using it correctly ?
i have a TOPLINK model : HW593Pro it hase 4 antennas and im usin the last one from the left side
im using postimg.cc
yes i scratched it off
,,,pay attention to the connections to both the antenna and the router...!!!
,,,what kind of connector did you use here...???
 the connector i used is from a tv receiver
and  about the soldering it didn't stick to the aluminium so i solder the cable from both ends ands
should i use another metal for this ?
and what about the dimensions i found out that my region is using a 40 band 2300 Mhz
should i cut it to be like the first model?
Your connector is not good, change it.,,,same with the router connection....!!!!
BRASS is great...Copper would be BETTER...(signal is LOST on small little defects on the way from Wireless card trough the antenna final contact point) CONTACT should be FIXED no play...
LTE Band 40 uses the 2300 MHz to 2400 MHz frequency range (FIRST the FREQUENCY then the BUILD around SUCH frequency) you seem to be getting NO SIGNAL 2 db is nothing
mitiche...try this,,,,
if the connection is TOO BAD (75 ohms cable on wrong connectors , bad contact impedance high VSWR) it might be switchin to INTERNAL ANTENNA...hence 1-2 dbi gain
okay sir im getting Busy this week ill try this next week thank you for your help
router no support externel antennas
Your problem is with these two connections....
All LTE BS have X-pol polarization, according to open sources.
Explain why the receiving MIMO antennas are still all set to X- polarization.
So I think you should have two connectors on the antenna.
hello sir it's been a while i  was busy with allot of things so yesterday i got som time and i made 2 of this model
the dbi got from 101 to 84
i isolated tge V plate and I had some trouble fixing the iron wire to the aluminium plate
but im happy with the result
so next time ill make the V plate with copper plate
thanks again for your kindness 20260129_215828.jpgScreenshot-20260129-215428-2.jpg
,,,this is how the two antennas should be connected at 90 degrees polarization...
what do you mean should i reposition the antennas to 90% one horizontal and one vertical or the feeds of the antennas ?
Edited by mitiche
1468-970-thumb-jpg-63279babaa5e8af7e12f3
PS, MITICHE, I WOULD LIKE TO ASK YOU HOW DO YOU POST THE IMAGE ON THIS FORUM...???
ahh okay so the feeds should be placed like this okay ill do it now and see the difference
i did like so but i got the same result 84 Dbm
so i got this
can i use it with the antennas ?
,,,yes,you can only do it with a single antenna with 3-7 elements...!!!
will it  be better if so please give me the dimensions for band 40
i want to try it
Edited by mitiche
i want to try it
61a-thumb-jpg-4fd8c5f461ea7312b87ee0adb6
