Collinear antenna array
71 posts in this topic
hello brother how are you, long time to see
i would try to make like this, what do you thinking
Another good collinear antenna with a 9 dBi directivity gain...
Proposed dipole array antenna which makes omnidirectional  radiation possible and is made of coaxial cable with metal cylinders...
what is the formula for calculating rubber duck antenna
HALF Wavelength with stub balun 1:1 (reduced in length due to dielectric effect )
so it will end up being two sections of about 30 mm IMHO
https://www.allaboutcircuits.com/uploads/articles/2.4GHz_Wi-Fi_Antenna_.5_Wavelength_Dipole.png
In the sleeve dipole the top element is normally  simple the coax center conductor extended. This is also normally left with its insulation intact, which means its length must be compensated for by the insulation's permittivity. (the antenna is SHORTER than an a free dipole ; wich is (speed of light/frecuency ) / 2 )
Maksud saya apakah ada formula untuk membuat antena ini ,
formula for impedance adjustment to 50 ohms or 75 ohms
Edited by Ingsun
,,, construction of a simple collinear antenna...
,,, and yet no, this omni antenna is not well sized...
,,, it is for 2.63 Ghz
and this is the reality after resizing...
On 1/2/2017 at 2:23 PM, Admin said:
What should the dimensions be for 868mhz?
On 10/22/2017 at 4:04 PM, Admin said:
", you can try a simpler construction
Please show us the connection or soldering inside those tubes.
Which wire solder to where and how to solder it.
Thank you.
,,,where did you get this picture from?
,,,but I think this is it...!!!
I tried a similar design to this and hell yeah looks like it works.
On 28.01.2017 at 2:13 PM, Admin said:
@Admin, Is there a CST file you could share ?
Edited by Docgi
40 minutes ago, Admin said:
,,,точка живлення там не розташована...!!!!
Can you correct me because I don't quite understand what you're talking about?
