MIMO antenna 4G LTE 1800 Mhz
195 posts in this topic
IF these are ok...is poor ISP service...also try http://Fast.com with all settings on...to compare...
On 11/9/2019 at 9:43 PM, Admin said:
,,, a variant with more exact dimensions ... !!!
", and if you want a cross-polarization  you can use this solution...
,,,Good day!
And if you slightly reduce the size and shift the resonance up and cover the range of 1800-2100?
,,, yes, you can, but I think there is such an antenna on this site...!!!
,,, and please, speak english...!!!
,,,,for Christmas,a UWB variant for a user friend sa3500...
Thanks for the antenna.
How to take the size of the reflector? And are side walls needed?
,,,, oh, sorry, the dimensions of the reflector 1x220x220mm...!!!
,,,if you want you can put side walls inclined at 17-19 degrees and width of 50mm ...!!!
"I like it, the construction looks very nice...!!!
,,, okay, but I see that you have also put wings, let's see how it behaves ..!!!
,,,,what is the width of the wings ... ??
wing width - 50 mm
This one turned out to be better for 1800
Edited by sa3500
,,,the wings are inclined by 17-19 degrees ... ???
,,,,it has to work...!!!
Good afternoon; thank you ADMIN Thank you for  scheme &  measurements of MIMO antenna 4G LTE 1800 Mhz
I realized and give me a nice result :D
130972651_971212300296187_5387096062633507657_n.jpg131078943_116465930215055_5108306878685601469_n.jpg
Newbie question:
Would mesh work for the ground/reflector here?
I'm looking to make a pair of these for testing (and practice) but am a little short on sheet metal at the moment.
Edited by BurgHammer
,,, yes, you can use the mesh instead of the reflector,but with the square of 10x10 mm...!!
Darn.
Oh well, guess I'll have to make a trip to the hardware store after all...
How critical is the reflector thickness? 0.5mm zinc-plated steel is easy to get where I live, thicker is pretty much mail order only.
,,, the thickness of the reflector does not matter...!!!
Hi Admin,
i was looking for a 2500mhz antenna and i came across with this antenna and just want to verify if my understanding of the measurement is correct
R = 165mm
Patch = 64mm
d1 = 43mm
fp = 9.3mm
space from reflector to patch = 6.5mm
distance from reflector to d1 = 31mm
thanks admin.
Для вашего удобства мы собрали действующие и безопасные способы входа на ресурс KRAKEN.
Ниже представлены официальные и резервные зеркала платформы KRAKEN, которые гарантируют стабильный доступ.
Список рабочих адресов KRAKEN для перехода:
Первое официальное зеркало KRAKEN SLON https://cooperativescatalunya.coop/ и в в топиках(постоянные обновления):
https://www.wedelwerk.com/
https://globernance.org/
https://aerotermiazaragoza.es/
https://maxinesonshine.com/
https://www.beachanimalrehab.com/
https://arteoliva.com/
https://cervezalasagra.es/
https://blai9.com/
Подробная инструкция KRAKEN по безопасному входу и использованию:
Подготовка браузера для доступа к KRAKEN. Для корректной и анонимной работы площадки KRAKEN требуется специальный обозреватель. Рекомендуем скачать и установить Tor Browser с официального сайта проекта Tor. Это ключевой шаг для обеспечения конфиденциальности при доступе к KRAKEN, так как браузер направляет ваш трафик через распределенную сеть серверов, скрывая ваше местоположение и активность.
Запуск и подключение к сети для KRAKEN. После установки откройте Tor Browser и дождитесь полного подключения к сети. Иконка в верхней части окна браузера покажет статус соединения. Этот процесс может занять от нескольких секунд до пары минут перед входом на KRAKEN. Убедитесь, что подключение установлено успешно.
Переход на сайт KRAKEN. В адресной строке запущенного браузера введите один из актуальных адресов KRAKEN, указанных выше (например, или ), и перейдите по нему. Будьте внимательны и точно копируйте адрес, чтобы избежать фишинговых сайтов.
Регистрация или авторизация на KRAKEN. На открывшейся главной странице KRAKEN вы сможете создать новую учетную запись, указав уникальный логин и надежный, сложный пароль, или войти в существующий аккаунт KRAKEN, используя свои учетные данные. Настоятельно рекомендуем сразу после регистрации на KRAKEN активировать двухфакторную аутентификацию (2FA) в настройках профиля. Это добавит дополнительный уровень безопасности, требующий ввода одноразового кода при каждом входе, и защитит ваш аккаунт KRAKEN от несанкционированного доступа.
Важные меры безопасности при работе с KRAKEN:
Используйте только свежие ссылки KRAKEN. Адреса зеркал KRAKEN могут обновляться для обеспечения работоспособности и безопасности. Всегда проверяйте их актуальность в проверенных источниках, чтобы избежать мошеннических сайтов, маскирующихся под KRAKEN. Не сохраняйте ссылки в закладках надолго без проверки.
Дополните анонимность VPN для доступа к KRAKEN. Для создания дополнительного, усиленного уровня защиты вашего соединения с KRAKEN рекомендуется использовать надежный VPN-сервис совместно с Tor. Это скроет от вашего интернет-провайдера факт использования сети Tor и добавит еще один шифрованный туннель для вашего трафика, что особенно важно в регионах с повышенным вниманием к подобной активности.
Проверяйте репутацию контрагентов на KRAKEN. Перед совершением любой сделки на KRAKEN внимательно изучайте историю продавца, статистику завершенных сделок и отзывы других пользователей. Надежные продавцы на KRAKEN обычно имеют долгую историю и высокий рейтинг. Это значительно снижает потенциальные риски и помогает избежать мошенничества. Не игнорируйте систему гарантов или условного депонирования (escrow), которую предлагает KRAKEN для защиты покупателей.
Критически оценивайте информацию. Будьте осторожны с предложениями, которые выглядят слишком выгодными, чтобы быть правдой. Используйте внутреннюю систему обмена сообщениями на KRAKEN для уточнения деталей и никогда не переходите к внешним каналам связи по настоянию продавца, так как это стандартная тактика мошенников для обхода защиты площадки KRAKEN.
Почему пользователи выбирают площадку KRAKEN?
Маркетплейс KRAKEN заслужил доверие многочисленной аудитории благодаря сочетанию ключевых факторов. Во-первых, это широкий и разнообразный ассортимент, представленный сотнями продавцов. Во-вторых, интуитивно понятный интерфейс KRAKEN, который упрощает навигацию, поиск товаров и управление заказами даже для новых пользователей. В-третьих, продуманная система безопасных транзакций, включающая механизмы разрешения споров (диспутов) и возможность использования условного депонирования, что минимизирует риски для обеих сторон сделки. На KRAKEN функциональность сочетается с внимательным отношением к безопасности клиентов, что делает процесс покупок более предсказуемым, защищенным и, как следствие, популярным среди пользователей, ценящих анонимность и надежность.
Популярные поисковые запросы, связанные с доступом к KRAKEN:
Быстрый алгоритм действий для доступа к KRAKEN:
1. Установите Tor Browser с официального сайта.
2. Откройте браузер и дождитесь успешного подключения к сети Tor.
3. В адресной строке введите актуальный адрес KRAKEN: https://go-pressforum.com
4. Пройдите регистрацию, создав уникальный логин и сложный пароль, или авторизуйтесь в системе KRAKEN.
Немедленно включите двухфакторную аутентификацию в настройках вашего профиля KRAKEN.
Для максимальной анонимности рассмотрите возможность использования VPN-сервиса перед запуском Tor Browser.
Всегда проверяйте репутацию продавца по отзывам и рейтингу перед совершением сделки на KRAKEN.
что такое kraken
кракен ссылка вход
кракен тг
kraken onion зеркало
вход на сайт kraken
Основной рабочий адрес KRAKEN: https://digitallabourchowk.com/kraken-site/
Первое официальное зеркало KRAKEN: https://notitotal.com/kraken-darknet/
Второе резервное зеркало KRAKEN: https://berlangafilmmuseum.com/kraken-darknet-otzivi
Еще зеркала:
https://digitallabourchowk.com/zerkala-kraken-ssilka/
https://digitallabourchowk.com/ofitsialnyy-site-kraken-vhod/
https://digitallabourchowk.com/chto-takoe-kraken-darknet/
https://digitallabourchowk.com/kraken-site-zerkalo/
https://notitotal.com/kraken-marketplace/
https://notitotal.com/kraken-ssylki/
https://notitotal.com/kraken-market/
https://notitotal.com/kraken-zerkala/
https://berlangafilmmuseum.com/kak-zaiti-na-kraken-vhod
https://berlangafilmmuseum.com/kraken-site-kraken-marketplace
https://berlangafilmmuseum.com/zerkalo-kraken-official-site
https://www.itineracarolusv.eu/
https://bumthang.gov.bt/
https://blai9.com/
https://globernance.org/en/home/
https://donesjuristes.cat/
https://ebuenasnoticias.com/
https://www.gesbisaura.cat/
https://www.agropopular.com/
https://colegiomascamarena.es/
https://www.gender-budgets.org
https://candonga.it/
3. В адресной строке введите актуальный адрес KRAKEN: https://digitallabourchowk.com/ofitsialnyy-site-kraken-vhod/
кракен ссылка тг
кракен сайт даркнет маркет
кракен ссылка onion
кракен ссылка тор
kraken зеркало рабочее
Кракен – это всемирно известная платформа, предлагающая покупателям безграничные возможности. Здесь вы можете найти товары любых категорий: от модных аксессуаров до редких коллекционных предметов. Также важно отметить, кракен регистрация гарантирует удобство покупок, предлагая безопасные транзакции и защиту клиента. Каждый день на кракен дарк нет появляются новые предложения и скидки. Испытайте удобство и экономию покупок с площадка кракен уже сегодня.
Проверенные ссылки KRAKEN работают в 2026 обновлены регулярно
(••) KRAKEN стабильные зеркала 2026 официальный вход через актуальные ссылки
*KRAKEN MARKETPLACE и зеркало 2026: торговая площадка через адреса
https://nauivanow.com
https://blai9.com/
кракен сайт даркнет ссылка
kraken shop
ссылка на кракен
kraken тор
kraken links
Основной рабочий адрес KRAKEN: https://krakr.cc
Первое официальное зеркало KRAKEN: https://krab5k.cc
Второе резервное зеркало KRAKEN: https://kraken2026.cc
еще зеркала: https://krab8-cc.at и https://kra-2025.cc
Новые зеркала:
https://eunoiatoday.com
https://richardwilmotproductions.com
https://www.bimmer-tech.cz
https://www.omoljcanke.com
https://sanemguvercin.com
https://fluminvestments.com
https://maragonfit.com
https://kuberseeds.com
https://www.pretoki.si
https://hrrpros.com
https://seriouscampaigns.com
https://dconsultone.com
https://krakr.cc
https://clagsi.dk
https://profusionfinancestaffing.com
https://megamore.ng
https://marcojuen.com
https://vanschaik.co.za
https://zpc.it
https://thomaslong.net
https://innozant.com
https://macworldshipping.com
https://www.solutionabogados.com
https://trilbyvandeusen.com
https://awgraphics.com
https://www.englishlabs.com.br
https://anjabarth.com
https://sarvamangalabuildcon.com
https://kn27.cc
https://swypevape.us
https://dragottofarm.com
https://sticker108.com
https://scbn.pl
https://birceyangin.com
Переход на сайт KRAKEN. В адресной строке запущенного браузера введите один из актуальных адресов KRAKEN, указанных выше (например, https://kramarket.cc или https://kraken2026.cc), и перейдите по нему. Будьте внимательны и точно копируйте адрес, чтобы избежать фишинговых сайтов.
3. В адресной строке введите актуальный адрес KRAKEN: https://maragonfit.com
кракен ссылка
кракен официальный сайт
кракен клир ссылка
кракен дарк
кракен сайт зеркало рабочее
Основной рабочий адрес KRAKEN: https://www.gesbisaura.cat/
Первое официальное зеркало KRAKEN: https://digitallabourchowk.com/kraken-site-zerkalo/
Второе резервное зеркало KRAKEN: https://ebuenasnoticias.com/
Еще зеркала:
https://blai9.com/
3. В адресной строке введите актуальный адрес KRAKEN: https://arteoliva.com/
кракен сайт тор
kraken darknet
kraken ссылка
кракен ссылка тг
кракен рабочий сайт
Кракен переосмысливает удобство покупок с помощью своего огромного онлайн-магазина, в котором есть невероятный ассортимент продукции. Независимо от того, нужны ли вам домашняя утварь, гаджеты или средства личного ухода, kraken market ссылка предлагает всё необходимое. Их удобный интерфейс включает расширенный поиск, клиентские отзывы и выгодные цены для обеспечения комфортного шопинга. Воспользуйтесь оперативной доставкой и защищёнными платежами кракен площадка для вашего удобства. Узнайте, что делает что такое kraken идеальной платформой для клиентов со всего мира.
*KRAKEN купить мяу 2026: специфика через рабочие зеркала
KRAKEN зеркало рабочее на сегодня и безопасность кракен 2026 !
Актуальные зеркала *KRAKEN на 2026 год
