Biquad Antenna
423 posts in this topic
,,, that would be ... !!!!
Thanks, my friend
I want this antenna for fpv
I will definitely make your design and test it on the UAV
I bought the antenna you see in the picture
I haven't tested it myself yet, but apparently it works great
My friends tested and reached a range of 30 km with a power of 1 watt
I do not need this amount
Coverage is more important to me
For example, with two diversion receivers and 90 degree coverage and 10 dbi gain for 10 km distance
I have a few questions to make this antenna
1. If I use fr4 with a thickness greater than 0.8, like 1.6 and add to the height will the antenna have the same performance? Or do I want to use a steel plate instead of its FR4?
2- Is the thickness of copper 0.25? Is there a problem for me to use 0.35? (Finding a 0.25 board is really hard)
3- Is it possible to design based on multiples of lambda? Because the network may be busy, I have to switch to Frequency 5280
Thank you in the end
pcb antenna 5.2ghz.IGS
1) No.
2) Other dimensions are required for 0.35mm copper sheet.
3)The antenna simulated by me , works just as well for the 5.0-5.5 GHz frequency range.
2 minutes ago, Admin said:
1) No.
thanks
In our area, only PCBs with a thickness of 1.6 and a thickness of 0.35 can be found
Is it possible to design for this type of material?
,,, I will do a simulation for PCB 1.6mm thick as well as for antenna only 0.35mm thick sheet...!!!!
oh realy thanks
,,, this is what the 0.35mm thick sheet looks like...
thanks admin
Please give me the sizes of this design as well
Or is it the same size as before?
Edited by mojtaba.hdpr
Hi admin
do you here ?
,,, but I think it's better that way ... !!!!
Hi admin
what are these ? is copper ?
just support or ...
,, is one and the same with antenna ,,, copper sheet or galvanized sheet...!!!
biquad 4500(Russian 5G)-6000
t=0.2mm
h=12.5
reflector = 56x56 mm
connector - SMA
,,,biquad for 1700-2700 MHz-dimensions...
,,, it is recommended to show all dimensions...!!!
7 hours ago, mojtaba.hdpr said:
thanks
Can this design be used for biquad?
sorry for double biquad i mean
,,, yes, I think it could be ... !!!
can you design ?
,,, it could be something like this ....
Biquat + Horn for 2.4 - 2.5 GHz & optimized for gain
Size
Spoiler
Impedance + Gain
Spoiler
Parameters:
Spoiler
wsq="5.8" "with square"
lsq="24.1" "length square"
h="23.1" "height"
g="0.5" "thickness material"
w="(l-wsq)/2" "with biquad"
ded="l/4-we1/2" "distance edge"
ded2="l/4+we1/2" "distance edge 2"
l="158.3" "length biquad"
e="4.3" "edge 3 biquad"
s="4.8" "hole diameter"
s1="49.0" "length slot"
sl="0.5" "slot"
x="248.2" "reflector x"
y="128.7" "reflector y"
we1="4.0" "with edge 1"
hc="177.0" "height collector"
ang="13.9" "angle collector"
File:
Biquad 2-4ghz-double-reflector.cst
Edited by Dr. Pepper
,,, congratulations doctor, but I think you need to work a little on the impedance, it should cover a wider band of frequencies...!!!
You are right, its not perfect. But the first goal was reach 16 dBi. I will try to tune the design for a more stable range.
  Reveal hidden contents
h="23.1" "height"
sl="0.5" "slot"
This antenna can be used in a wider range without visible loss.
It can be done much easier. please display the SWR graph from 1. It cannot be less than 1 (apparently CST does not know this), this complicates the reading of the graph.
To increase the gain, you can use the director system. Read the topic
