Biquad Antenna
340 posts in this topic
I made this anthenna and want to make it in PCB.
Forget about PCB, it's not good...!!!
Why? Because it is difficult to make it from a printed circuit board?
,,,no,PCB has poor results...!!!
25 minutes ago, KSM said:
What if I build it using 1 mm M1/M2 copper?
Yes, it's fine, the thickness of the material doesn't matter.
,,,but what is "M1/M2"...???
Copper comes in different grades: M00, M0, M1, M2 and M3. The grade is determined by the purity of the copper content. M1p, M2p and M3p copper contain 0.01% oxygen and 0.04% phosphorus. Copper grades M1, M2 and M3 contain 0.05–0.08% oxygen.
No, the purity of the copper doesn't matter...!!!
Brass might be better not so easy to oxidize...or protected from moisture PURE COPPER...(aluminum, zinc,etc)
You'll have bigger losses on DIELECTRICS than metal every time
It's not good, what do you want to do..?
Two ports for a TP-Link MR-100 router outdoor antenna, it has 2 sma antennas, and I want to replace them for better signal gain, as the router cannot fitted outside, because need protection from rain.
I made a biquad in antenna-magus, exported to CST, and then doubled the elements making also a larger reflector.
Edited by papagayor
6 hours ago, papagayor said:
Dual Port Biquad, correct and suggestions please
Biquad.cst
it is better to make 2 separated biquad antennas with individual reflector each
they gonna work better
and with 2 separate you can experiment with -45 +45 polarization etc
I think this construction is better..!!!
