aurel
BatWing antenna 2.4 ghz
359 posts in this topic
On 08/04/2024 at 5:31 AM, Admin said:
,,,I considered it sensible to resume Aurel's idea from the beginning and to present a version of the Batwing wire antenna...
Beautiful!
"I don't know exactly, it might exist on this site, but anyway I'll resume simulating this antenna...!!!
Anyway, look here...
I'm still trying to make some optimizations for this kind of antenna.
,,,and yet it can be done better by doubling the distance "w"...
I also tried a version of the Batwing antenna, with small modifications....
,,,a variety of FPV antennas, including my Batwing antenna model...
https://efpv.in.ua/antena-batwing
Specifications
Frequency range 1800-2800 MHz
Beam angle 50°
Connector SMA-F
Material aluminum
Gain 10 dBi
Size 144*99*48 mm
Weight 115 g
On 22.04.2019 at 4:17 PM, Admin said:
Hi, if I connect the antenna and the reflector with metal, will that be correct? Or does this antenna only work with dielectric?
Hy buddy...!!!
It would be preferable to connect the antenna to the reflector with wire
