BESTER BDM-2 MIMO 4G/LTE ANTENNA, 15-17 DB
137 posts in this topic
,,,this is the correct positioning of the Bester antenna...
Posted (edited)
Hello admin... what is the best option you have with square elements for 1800 MHz?
How many elements should I have to reach 14 db or 15 db?
Edited by Edel2020
,,hi buddy...!!!
I'll try to do a simulation for you, but I think the antenna will be big enough for the desired frequency.(length=420 mm)
Thanks friend... I just can't stand making more circles anymore... it's easier and much better to test this way. Can you use a central support wider than 6 mm?
,,yes,6---8 mm...!!!!
,,,but I think a panel antenna would be better...!!!
Yes.. it looks good, I could try... give me more construction details
Sorry, but the D1 measurements were missing.
D1=99 mm
,,,and because I saw that you like square patches...
Excellent ... now if I'm going to try JJJJ ... only the measures of the patches are missing on the edge of the reflector.
Could it be covered with a specific plastic or can it be anyone?
A question ... The square bester D1 would be 99 or 69?
,,,yes,it could be covered with a plastic...
,,,sorry for the mistake, D1=70 mm
Idea Of  Jomy. I made it. The last year
