lrg
AX-2600 OFFSET 75 MIMO 2x2 офсетный облучатель 4G
57 posts in this topic
17 hours ago, Admin said:
,,,well Irg, but for which frequency do you want...!!!
In this topic of course same on 2600 MHz . and it would be very smart for two frequencies of 2600 and 1800 MHz.under the 75 Ohm cable
Here are the dimensions posted by Chilanzar, for the 1.8GHz frequency...
Thank you so much. it's an important frequency for me.I have already started manufacturing          : -) .in General, it would be interesting to know the size of the irradiator at 2.6 MHz
"Irg, I will soon adapt the antenna for this frequency....!!!!
Sorry I hurried and did not even ask about the thickness of the metal patches in this irradiator
What is the thickness of the metal used in this feed?
I think Chilanzar could inform you best...!!!
" it might be 0.5mm...!!!
Chilanzar? Where can I find it?
,,, here, on this forum ... !!!
"chilanzar2"
тольщина патчей - 0.7мм.
Но, мне не нравится этот облучатель. Я ищу 1700-2200 MIMO
the thickness of the patches is 0.7mm.
But, I do not like this irradiator. I am looking for 1700-2200 MIMO
Подскажите толщину стоек. Я нашлол от приборов.чтобы меньше их переделывать. Нет поблизости токаря.
Tell me the thickness of the racks. I found it from devices. To reduce them less. There is no nearby turner.
Tell me the thickness of the racks. I have these.they probably will be able to come up with some small alterations.there's no lathe in the vicinity.:-)
on the irradiator Antex is used 6mm. I use 4.7 mm. other I have no...I buy on aliexpress
It is clear you used computer racks on which the motherboard is installed.
нужного размера очень тяжело найти в компьютерах - поэтому лучше искать и покупать на алиэкспресс
the right size is very hard to find in computers - so it's better to look and buy on aliexpress
  Like this
,,,good, another constructive form of this antenna, with built-in modem...
Chil, I think it's all M3 screw, but with a step more than 0.5mm (0.6 ... 0.7mmm))
this is the American standard. we don't have these nuts. No in Europe.
On 14/11/2017 at 1:29 AM, lrg said:
Dimensions are not clear here, reflector to the first patch 4mm.. reflector to the 2nd patch 6mm.. so from the 1st patch to the 2nd patch only 2 mm? it's seems more
,,, Kledi,this is not the place of this antenna, move it...!!!
 I will delete this post...!!!
Yes admin this is the offset antenna dimension, watch the first page..
,,, oh, yes, you're right, excuse me ... !!
,,,these are the dimensions...!!!
 I think I will recalculate this antenna for optimization.
Thank you! I have only 1mm galvanized steel, Will It work? I cant find 0.5mm here in my town
,,,yes, you can use 1mm thick...!!!
,,, try to delete the double images above...!!!
Can we have a mimo 1800-2600 feed offset antenna  please ?
