Sector Antenna 2,442GHz
91 posts in this topic
Yes, but not with this patch geometry...!!!
On 1/9/2018 at 9:50 PM, Admin said:
A new patch format...for broadband
You have detail size for this antenna ?
,,,good, if you look carefully on this site, you will find what you are interested in ... !!!
On 4/23/2017 at 8:35 PM, Admin said:
After an idea of Vman...
this one?? but with eight patch right...
I think not easy to find wire with 1,6 size,  if i change the wire size to 1.5 or 2 mm. is there a change in antenna measurement, maybe the distance between the patch and the reflector, or the size of the patch or other?
or do you have to still use the wire size to get best results?
Edited by bejonet
,,,this is better,this is the best...
6 people like this
51 minutes ago, bejonet said:
and where i found the detail...?
good thank you,, but it is for 1800mhz, that i need is 2300-2700mhz
Yes, you are right, at this antenna I did not give details, I will post them later...!!!
thank you, will remain faithful to wait for the results of the details
chances are less precision, because cutting by scissors,,,
just make the reflector
it is possible for mimo???
Edited by bejonet
the antenna is finished, can it use the teflon sheet to cover it?
for the feed, whether it is right on the edge or there is a distance from the edge
,,,it"s good...!!!
Tell me, are you taking the test today?
yes, i was tested and it working very good, i like it
what polarization and angle beamwidth for this antenna?
if add more patch, can be increase the gain?
hi admin...
it is posible to copy mantbox reflector for this sector antenna???, mimo with single polarization of course..
,,,you can do instead of 110mm to 95mm , but the gain in directivity will be lower....!!!
