AX-2017P panel 3G antenna (17 dBi, 50 Ω)
65 posts in this topic
 I think we should move the current topic to the topic..."Remo Street Connect 3G/4G Universal"
That's about the dimensions...
On 9/30/2019 at 10:08 AM, Admin said:
Николай, если вы возьмете две такие антенны и откажетесь от адаптивных линий для port2, а также сделаете горизонтальную регулировку между ними, вы получите антенну с коэффициентом усиления 17dBi..
,,, ???????????)))))) These are blanks for the future antenna. Each section individually showed good results. Need to be tied together, I hope you understand?
 Nickol, be careful how you position the transmission lines...
"Sorry, I took care of Remo, but it solves your problem ... !!!
15 часов назад, сказал админ:
- Извините, я позаботился о римо, но это решает вашу проблему ... !!!
????Я очень разочарован....
,,, why ... ???
,,,all elements should be excited in-phase...!!!
 ,,,and it is best to make the adjustment with the inclined sides...
,,,you can take a transformer from Remo...!!!
On 10/2/2019 at 4:41 PM, Admin said:
,,,вы можете взять трансформатор из Ремо...!!!
Thank! The antenna is almost ready, maybe tomorrow I will do the first test if everything goes well ...
The AX-2017PF panel antenna is intended for use in a set with 3G modems (routers). The antenna type is common-mode array. It is recommended for use at the borders of service areas, when the 3G signal level is weak and unstable, as well as in the case of a long connecting cable between the modem and the antenna installation point.
The AX-2017PF is a version of the AX-2017P antenna, but only for a 75 ohm cable. The antenna uses an F-female connector (a conventional TV connector with a thread), which makes it possible to make cable assemblies directly by the user without resorting to the help of specialists, without using special tools. By using a SAT703 TV cable instead of a 50 ohm cable, you can save a lot of money .
Electrical characteristics
Operating frequency range, MHz 1900-2200
Gain, dBi 16÷17
Bottom width in the H-plane, deg 32÷40
Bottom width in the E-plane, deg 16÷19
Side lobe level, dB max -13
Forward / backward ratio, dB not less 20
Input impedance, Ohms 75
SWR in the operating frequency range, max. 1,5
Permissible power, W 10
Polarisation vertical/horizontal
Weight with mounting, g 1800
Overall dimensions without mounting, m 0. 45x0. 24x0. 05
Connector F-female
Antenna Material steel, galvanized steel
Protective coating powdered polymer paint
Material of the protective box Polycarbonate+ABS
