papagayor
N78 Antenna
85 posts in this topic
A disc without CUTS or SLOTS is Linearly Polarized...tho
Please explain me, does this affect performance? Should I make the "cuts" on 2nd disk at about 5mm???
Testing on CST looked like there is not much difference........
In any case thank you for watching, if you can suggest something it's welcome, in any case I upload the CST file for make things easier.
FINAL-BESTER-7-5-4-3-HEX.cst
depends on the PROVIDER Polarization if it's linear Vertical Horizontal at 90 degrees is ok...(if Circular you lose several DB) ussually is slanted -45 +45 (90) so rotating the feeder slightly you should get a little more or less gain
Oufffff, using Cosmote in Greece, it has "linear vertical" polarization. And you see the problem is not the construction correction, the problem is .....re-mounting it!!! Very helpful your suggestion, I learned something more, thank you.
Try to bring them onto the same axis of symmetry...
You're right. Have to find a solution for this, the problem is that the LMR's are to thick and difficult to turn them, also they don't leave much space behind, I'll find a way to correct this. But I don't understand the "red lines" to "green line" alignment???????
Edited by papagayor
ONE of the TWO RED lines in the picture should be the same that the DISH to LNB support (one of those TWO red Lines should be ALIGNED with the dish LONG side height---
На сайте представлена полезная информация о том, как купить лодочный мотор и выбрать подходящую модель для вашей лодки. Узнайте больше про лодочный мотор 9.9, его характеристики и преимущества. https://codeberg.org/Spyship/spyship/issues/1
Если вы планируете лодочный мотор купить, на сайте собраны советы и обзоры популярных моделей. Особое внимание уделено двигателям лодочный мотор 9.9 про и другим надежным вариантам. https://secondstreet.ru/profile/Spyship/
Подробная информация для тех, кто хочет купить лодочные моторы для рыбалки или отдыха. Узнайте, чем отличается двухтактный лодочный мотор и какие модели лучше подходят для разных лодок. https://sitebs.ru/blogs/122104.html
На сайте можно узнать, какие лодочные моторы купить для комфортного отдыха на воде. Популярные решения включают 2х тактный лодочный мотор и модели мощностью 9.9. https://blogfreely.net/inkwave/lodochnye-motory-kak-vybrat-podkhodiashchii-dvigatel-dlia-rybalki-i-otdykha
Ищете, где купить лодочный мотор 9.9? На сайте представлена информация о характеристиках, особенностях и преимуществах этой популярной модели. https://yoo.rs/-1773964443?Ysid=285574
