papagayor
N78 Antenna
84 posts in this topic
You'll make me go on buying a new laptop as these calculations are very heavy. I own a Lenovo L490 with 8365U, running Debian and Virtualbox running Win10 which then run CST!!!
I'm not sure about tubes height, I'll try to lower tubes at a distance of 1/4λ as this is the proposed distance I have seen online samples
Yes, that's about it...still needs work...!11
,,,it's also possible...with cantenna...
,,,with some disk plate as directors....
You mean to attach a yagi-disk as director into a cantenna  but using probes for signal as in cantenna? Or just put the whole construction in cantenna box for better performance? Cannot understand this plan.
Yes, there are two versions of the cantena, a simple one and a combined one.
Here's the problem, you have to keep this in mind....!!!
OLE, I think getting better by working on CST, that's my new design for a similar to Kathrein element, not so good but looks to work, also if mounted on a parabolic dish, maybe it give much more gain. Now trying to decrease the VSWR
KathreinPLAN.cst
when looking for Interference between solids , watch closely if you want to TRIM the first one (metal overlapping dielectric) or INSERT the Dielectric into the METAL that overlaps... TRIM or INSERT are the most useful commands before simulation...
Thank you my friend, I'm new on CST design but trying to learn by seeking online for help, also continue to design different models and simulate them for knowledge. I liked the Kathrein antenna design that is simple and very stable and trying to make a prototype at 3.5GHz center frequency and a bandwidth of 3.3-3.8 because that is the working 5G area in Greece
...find one working HERE or anywhere and SCALE DOWN-UP to 3.5ghz that's the easiest way...(You'll NEED the CST or 3d model)
On 24/4/2025 at 6:21 AM, papagayor said:
Thank you very much sir, but please can't my drawings be modified to work in this area? Because they're easy to be made for my skills. Also a dual polarized batwing with two ports would interesting.
How do you feed this, Not easy to make. What do you think.
What's the plan...mimo Circular polarization...V and H pol...?
So, back again after Summer work. Going on constructions and need to know something about a Bester drawing Dual port antenna placement, I attach a plan and want to learn what is the correct placement for the antenna on a satellite disk:
Bester.pdf
Made one based on Admin's suggestion, from scarp metal that had, not attached yet on a parabolic disk, but seems to work good. Without antenna Ookla Speedtest was about 45-60Kbps, after over 80Mbps, testing from PC's ethernet connection, testing from mobile closed to router was over 100Mbps. Even it is made with bad stuff like thin simple wires and not good soldering as I didn't have some quality materials (I order some from Ali and waiting to go on for a new one), results are enough satisfying. But I don't understand why router shows "red" light and not "green" as it should if signal is good, suppose it is from speedtest,  any explanation please or any suggestions? Thank you.
5G not available or not registered...so it might be just on 4G...(which has a practical limit close to 100MBPS)
Here we are again. So, after received my order from Aliexpress, made this Bester antenna based on admin's suggestions and tested on CST. I ordered pre-cutted brass disks in Dia's 70-50-40-30 (70 at 1mm thikness and the other at 0.5mm), some sma's and also some Hex screws at desired length, with distances at 5,7 and 23mm form 1st to 4th disk. Also ordered 2 pc's of LMR400 at 1m each but it was impossible to fit both on router's T9 ports as the distance is short, so added two smaller cables, not sure about results adding them??? Below I attach a link of some photos of construction, testing with speedtest from any device (laptop via ethernet or mobile via wifi) the download speed was about 80-90Mbps, but it differs duRing day probably because in my village there is only one ISP antenna and it seems to be overloaded. Also it looks like even the SINR is not good, speed is not affected, anyway I'm trying to find a solution for this. Last is to make a cover for antenna protection.
Link to PHOTOS
Edited by papagayor
