streetdog
CST GENERATING GERBER FILES
HELLO ALL , IM NEW TO ANTENNA DESIGN . IM DESIGNING A TRIANGLE ANTENNA WITH TRIANGLE GROUND AND PATCH WITH COAXIAL FEEDING ( HOLE FEEDING). MY QESTION IS I HAVE CONSTUCTED THE CONNECTOR BY WACHING SOME TUTORIALS AND NOW CAN I USE THIS  THE NORMAL 50 OHM CONNECTOR WHICH IS AVAILBALE IN THE MARKET AFTER FABRICATION. AND HOW CAN I GENERATE THE GERBER FILES FOR THE FABRICATION . AND THE RESULTS I HAE ACHIVED IS 5.991 GHZ @ S11= -32.31 DB AND VSWR IS 1.049 AND GAIN OF 6.3DBI. IS THIS RESULTS ARE GOOD OR DO I NEED TO CHANGE ANYTHING? HOPE I GET THE SOLUTION THANKS.
welcome to this forum...!!!
if you can give some dimensions it would be better!
Gerber files are from CST-Studio...???
And why don't you write in normal letters?
hi , i have attached the picture with diamensions ,
yes from cst studio,sorrry  unfortunately wrote with caps lock , next time i will write in normal letter.
,,,but you need to show the positioning of the power point and the thickness of the PCB...!!!
, im using roggers RT5880 with thickness 0.787 mm and copper thickness is 0.035 mm
and feeding location is x = -1.5 and y = 3.
I think it's easier to post the CST file....!!!
Okay, then post the results...!!!
Okay, now post the images with the results obtained...!!!
Your file is completely wrong...!!!
