streetdog
CST GENERATING GERBER FILES
26 posts in this topic
2 hours ago, streetdog said:
thanks can you clarify that is drill for the sma connector will comes in manfacturing or need to make it later? thanks
All you need for a PLANAR (2d Microstrip PCB) antenna is a 2D drawing , PCB are standard thickness (single or double sided copper layer) the dielectric is the key FR4 Teflon Rogers...YOU NEED THAT VALUE to simulate it right...drilling is done after burning the NOT NEEDED copper zones...a small project could easily be done on COPPER TAPE and any dielectric support (CARDBOARD-STYROFOAM...etc)and would work BETTER than the same on PCB.LOOKS DON't MATTER Energy doesn't care.Only sees METAL=GOOD , Air = good , Dielectrics=BAD....
