Raytron 16dbi patch
37 posts in this topic
Raytron 16dbi & 19dbi mod
Hi , guys it would be nice if some generous soul simulate this one...
The original is 6 elements over 0.787 ptfe , 2.1 dielectric constant...
(Фольгированные материалы фирмы NELTEC (Франция)
NELTEC — новое название фирмы METCLAD.
Материалы предназначены для использования в качестве подложек в СВЧ-устройствах.
Материалы имеют нормированную диэлектрическую постоянную, низкий уровень диэлектрических потерь и уменшенную толщину слоя меди.
Основные параметры:
Толщина диэлектрика: 0.127, 0.254, 0.508, 0.762, 0.787, 1.270, 1.524, 1.575, 3.175 мм
Диэлектрическая проницаемость (на частоте 10 ГГц): 2.17
Panel_16dBi.pdf
Clanon, you're from Argentina and you speak Russian...???
,,, please write in English ... !!!
OK , "dude" ...already built it on a notebook ABS cover...with aluminum foil...CST simulation would be great to fine tunning it...
PD: I'm NOT getting 16dbi and a lot of VSWR
ABS should be like 2.8 of dielectric constant and 1.5 mm width ...try to keep 5mm to aluminum reflector inside , but it's tricky...not a lot of space
some wifi cards don't like it so it must be high VSWR...channels  from 1 to 11 all show up...poor signal though...
,,,well, the reflector where is ... ???
inside
bigger than patchs and close to 4mm or so the screws touch it on the current centers of the patch
Clanon, you can put the dimensions to it...???
here's the model...not exact just  taken from that picture...
can't make it dance though...
Maybe my settings are wrong for the solver... i tried waveguide and discrete port...TO NO AVAIL
raytron 16dbi.cst
54 by 46 mm each Patch...i think...
,,,try to import a SMA port from this forum...
some doubt about INTERSECTIONS...how its supposed to go...
... something like that ... !!!
Anyway, something is wrong ...
try with teflon ...2.1 dielectric constant...Original material ...close to 0.7...(0.762, 0.787mm)
PD: I was gettin LOTS of APs...but too litle signal... less than -62dbm...and a bunch with more than -
"Foil materials from NELTEC (France)
NELTEC is the new name of the company METCLAD.
The materials are intended to be used as substrates in microwave devices.
The thickness of the dielectric: 0.127, 0.254, 0.508, 0.762, 0.787, 1.270, 1.524, 1.575, 3.175 mm
The dielectric constant (at a frequency of 10 GHz): 2.17 ... 3.48
Copper layer thickness: 5, 9, 12, 18, 35, 70, 105 microns
Sheet size: 305x457, 406x457, 457x610 mm "
It SHOULD have one BIG LOBE...in the CENTER (16dbi) and some smaller ones around...IMHO
“Having carefully examined the cable entry point in the photos of the“ original ”, I came to the conclusion that there is not a“ bare ”microstrip, but something like a“ coplanar waveguide. ”Therefore, I provided for such an“ earthen ”polygon at the input
..., only in English, please...!!!
getting there...RE-modeled...
i'm gonna work on the coplanar waveguided thingy...now...
Radiation efficiency seems fine... vswr must be the problem...
YUP...it's like they're "Forcing" the wave to make a 90 DEGREES through the FEEDING LINE...IMHO...(it must be important) I'll keep you informed if i have success...to 15 or 16dbis...
