sa3500
6 Еlement loop antenna
54 posts in this topic
,,,maybe only with more directors...!!!
sounds good..!!
By the way, I am looking for a mechanically small and robust (panel ?) antenna (868MHz) with approx. 10 dBi gain, surrounded by steel on 5 sides.
Do you have any suggestions?
,,,what do you understand "surrounded by steel on 5 sides"...????
Reflector bent upwards on 4 sides to mechanically protect the inside of the antenna. I need a mechanically very robust antenna.
,,,4 sides,not 5 sides...???
sorry just an open front
and as robust as the following antenna:;)
,,,,aaaaaa, that's what you want..???
a little bit strange but the environmental conditions for these Antennas a quite challenging
,,,then you don't want my type of antenna patch anymore...??
No no of course it would be very kind to receive the CST-file of your antenna from you.
exactly , thanks !!!!!
What would you suggest to make this antenna mechanically more robust?
and one more director please!
and 50 Ohms possible ?
,,, okay, let's try...!!!
,,,should it be like that....???
,,, buddy, you know how to work with CST Studio...???
Something, but unfortunately I'm not that good and fast with it. I'm trying to learn.
I will try it with 2 directors, otherwise the antenna will be too long.
,,,it has a length of only 385 mm...!!!
I have to put it in a rugged enclosure too.
,,,on this forum you can find some information...!!!
I have done this monopole Yagi. It's not prefect but working fine in industrial environment . It's made from 20 mm steel mounted on a metal construction with N-Connector underside and has to work in both directions. About 5.4dbi ,VSWR 1.06 ,  S11 -30.5. Maxium  nearly horizontal.
,,,which antenna are you referring to...!!!!
What do you think about an antenna like this ? a commercial one. should reach 14dBi at 868 MHz !? Too fragile for my needs.
,,,if you have this type of antenna, please, if possible, give me its dimensions (I don't think it has 14 dBi gain).....!!!
I pick up again next week and will give you the dimensions. I did a short check with the Nano-VNA. I don't remember the values but didn't look bad.
Performance in the field was quite good.( I too don't believe 14 dBi gain).
In the meantime I'm trying to "ruggidize" your BiQuad a bit.
Vova0,77.cst
,,,the best, Bester Antenna...
,,, it is still possible...
