71 -
Everything posted by Edel2020
jjjj thanks for missing me.... I'm a pain in the ass jjjjj ...I don't know, recommend me one, but with enough gain, I always need more jjj.... or it could be like the one discussed in the topic but with solid elements and more bays
Please...modeling and measurements for 1800
Excellent ... now if I'm going to try JJJJ ... only the measures of the patches are missing on the edge of the reflector. Could it be covered with a specific plastic or can it be anyone? A question ... The square bester D1 would be 99 or 69?
Sorry, but the D1 measurements were missing.
Yes.. it looks good, I could try... give me more construction details
Thanks friend... I just can't stand making more circles anymore... it's easier and much better to test this way. Can you use a central support wider than 6 mm?
Hello admin... what is the best option you have with square elements for 1800 MHz? How many elements should I have to reach 14 db or 15 db?
Browsing Chinese wed I found these accessories, it seems like they are for cell phones, will they really work? They announce gains of 3 and 4 dB between 800 MHz and 2100 MHz
Toole ... that's what I have for now, I'll keep looking. The vibrator that sends you as a test is from the Antenna PF5000 and this balum that I had not seen before, but of this if I have no more details
Ahhh wait I found something....the reflector is in the image 60 degrees and the directors is 6.70 degrees
Too bad... I owe you this, it's what I have on hand, maybe you want to try other types of vibrators, I've seen this one in similar models
Here you have it...
Greetings group... I was given the schematic of an antenna that they say is the best in Europe at the moment, but I don't know what impedance this type of dipole has and if it will be as good as they say... could it be modeled and find out if it is as good?
ok thanks, I've seen this way, is it more efficient? What size would it be for your antenna? Would it alter anything else?
Greetings again, after trying many more complex and complicated antenna models from the forum, perhaps thinking that they would work better and being scolded by admin jjjjj perhaps for stupid questions..... I tried this antenna and walaaa!!!, I managed a connection stable at 1800mhz, with an acceptable size (I added about 14 elements), easy to build, little air resistance and almost immune to rain, it surprised me. How could I squeeze a few more db? perhaps modifying the reflector?
Hello friends, I found this antenna on my friend's channel https://www.youtube.com/@mul_onochannel1569, I would like someone to model this antenna to know how effective it is and if it could be optimized, it will also work with rods and a reflector. mesh? It is supposed to be for the 1800 mhz frequency.
hello greetings, any idea for an antenna for commercial fm with maximum gain and that is not of a monstrous size (no more than 3m)
Thank you very much, does the height of the patch to the reflector remain the same? If I wanted a 75 ohm impedance, what would I change?
Could it be tested for 1800mhz? I need those 15db
I think I will continue trying with the Yagi....?? 920cm pacyfic grid atenna with dipole feed (with coaxial splited balun and one reflector) will give You 19-22dBi, adequat Yagi will be 2m long and and should be carried out with great precision (+/- 0.1mm)
It's a shame, it's very simple...and yes, they are right...but what can I do? I live in a region with a lot of air and there is no signal below 5 meters. I cannot raise such a large dish to more than 10 meters without having to invest a lot in a good mast. What options would there be?
Clanón... can you help me with something like this for 1800 mhz, I thought about making the Yagi Extreme lll ...but no one has simulated it or confirmed the gain and how good it is
So...can we add directors? Would it work as a yagi?
It really looks simple....what design to do to get closer to 20db at about 20 km in band 3 1800 MHz?
