clanon
Members-
Content count
678 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Articles
Calendar
Blogs
Downloads
Everything posted by clanon
Did this with several rtl8187b with GREAT RESULTS (even better than a tp link722) MiniPCIe to USB adaptation PS: Make sure you have this two -D +D on the card (some cards don't have'em!)
FR4 have lots of disadvantages (efficiency at RX lost , losses at TX a lot ! , never know the Tangent loss and dielectric constant for each material , fr wouldn't be on POINT ever ) you'll need an antenna analyzer or vna to be on frequency PS: only "advantage" size is smaller than metal on air
https://www.lan23.ru/forum/node/318855
yeah , it's easy with the model....pretty sure you are gonna end close to 1 meter by 60 cm or more GRILL...
Wire grill (big 80 cms at least) OR parabolic dish EVEN BIGGER 1.2 1.5 meters
Easier ,for me, if YOU choose ANY 2-3 patches design (10dbi) ( need a frontal picture) and then we'll make it work at 725mhz...
Easily 12 dbi at 725 mhz
Could be made to ANY frequency , Circular pol (could be made lineal easy) efficiency could be better NOT using FR...
Been beating around the bush for years to find a Good 4x4 patch array... Higher than 21 dbi , good impedance through the whole band,low enough vswr, under -20dbi side lobes... the original design is for 12,5 ghz and almost none side-lobes Power distribution Ratio 1:5:5:1 Changed it to WiFi , distribution ratio 1:1:1:1 (Original design Eliminated Sidelobes at the COST of 1,5-2dbi of gain) I'm happy (some testing still needed ) REAL dielectric constant of Polystyrene foam is a guess (1.02-1.05)
4:1 balun (50 ohms to 200 ohms , 75 ohm to 300 ohms , etc)
Still testing , Imepdance needs some work still...But looks good so far) Copper tape under 40 cm long and wide...PES foam or PU foam dielectric
MikroTik QRT 5 is a dual-polarization 5 GHz microstrip panel antenna with a gain specified up to 24 dBi and integrated radio at just 31×32×5 cm size The plastic case looks quite robust and UV resistant. The microstrip antenna array inside consists of 64 elements (8×8), which result in 10.5° beamwidth (-3 dB). There is also a MikroTik RB911G-5HPnD-QRT board, which features a 2×2 MIMO 802.11an radio (AR9342 SoC) with 30 dBm tx power. The antenna is connected with two short MMCX pigtails.
- 30 replies
- patch array
- 24dbi
(and 1 more)
Tagged with:
https://youtu.be/iOmdQnIlnRo?t=924 ,,,why it doesn't work..??
Correct adaptation from 50 ohms to 300 ohms antenna (Quarter wave long should take velocity factor of Coax in length ) 0.66 PET , etc
a Ratio between antenna Impedance and radio impedance the bigger the difference bigger the losses...let's sat 300 ohm antena/ 75 ohm radio 4:1 VSWR = close to 40% reflected power on TX...on RX it's gonna be WORSE...(small signal)
0.2 0.3 BRASS paper...? and a sharp cutter...several tries (using a printed PAPER taped on top) cut through the printed lines...? solder the vertical strips... PS: 0.2 is pretty RIGID...
Yagis hit a WALL at 15 dbi most of the times (with 15 elements and a BIG reflector)...you need 2 for 18 dbi , 4 for 21 , etc
nope...BUT those complex feed networks steal gain (several db)
Water absorption should be adressed in PES foam...Changes ALL. PVC pipe has THIS weirdness...
LOOP should be CLOSED at feeding Points... then , EACH Loop should be feed with 90 degrees phase difference
Double lineal here , NOT circular "The polarization of the emitted signal depends on the spatial location of the antenna. Horizontal - horizontal, vertical - vertical polarization. [4] The horizontal position represents when both squares are next to each other, the vertical position is when both squares are placed one above the other." DoubleBiquadOmni-Antennafor2.4GHzWirelessLinkApplication.pdf
