4G LTE 24dBi Antenna
Type: Communication Antenna
Gain: 24dBi
Voltage Standing Wave Ratio: ≤1.5
Impedance: 50Ω
Max Power: 50W
Radiation: Directional
Connector: 2 × N Female
Antenna Size: 47.3cm*25.2cm(1.55ft*0.85ft)
Frequency Range:698-806MHz / 824-894MHz / 925-960MHz / 1710-1885MHz / 1920-1980MHz / 2110-2170MHz / 2500-2690MHz
Applications: For Wireless Router Signal Repeater Amplifier, etc
Compatible Model: For Huawei Router Modem
Type: Coaxial Extension Cable
Cable Type: RG58 / 50-3 Coaxial Cable
Connector A: N Male
Connector B: N Male
Plug Inner Diameter: Ø6.45mm(0.25in)
Plug Outer Diameter: Ø7.62mm(0.3in)
Cable Outer Diameter: Ø4.95mm(0.19in)
Wire Length: 5m(16.4ft)
Applications: For 4G LTE Cellular Amplifier, Signal Booster, Antenna, Cell Phone, etc
Feature
The antenna use For Wireless Router Signal Repeater Amplifier, etc.
The antenna compatible with For Huawei Router Modem.
Omni-Directional 24dBi Router, Wireless Transmitter, WiFi Booster Antenna.
Easy to install, increase signal strength.
On 12.12.2022 at 8:38 PM, alhaba.production said:
Looks easy to build
this is narrowband design, can cover 2440 +-40 MHz WiFi for example. This particular is sized to 2150+-30 MHz.
Because it is SISO design, you need 2 anennas and double total size for MIMO.
Edited by yurik82
I discussed this antenna here..
On 12/12/2022 at 6:18 AM, Admin said:
Near Antenna Feed Silicon Glue or another conductive glue?
,,,non-conductive glue...!!!
