mitiche
17 -
Everything posted by mitiche
will it be better if so please give me the dimensions for band 40 i want to try it
so i got this can i use it with the antennas ?
i did like so but i got the same result 84 Dbm
ahh okay so the feeds should be placed like this okay ill do it now and see the difference
what do you mean should i reposition the antennas to 90% one horizontal and one vertical or the feeds of the antennas ?
hello sir it's been a while i was busy with allot of things so yesterday i got som time and i made 2 of this model the dbi got from 101 to 84 i isolated tge V plate and I had some trouble fixing the iron wire to the aluminium plate but im happy with the result so next time ill make the V plate with copper plate thanks again for your kindness
okay sir im getting Busy this week ill try this next week thank you for your help
the connector i used is from a tv receiver and about the soldering it didn't stick to the aluminium so i solder the cable from both ends ands should i use another metal for this ? and what about the dimensions i found out that my region is using a 40 band 2300 Mhz should i cut it to be like the first model?
yes i scratched it off
im using postimg.cc
withe antenna without antenna hello sir i didn't get a good result its the same result with or without antenna im using the 1800 model and i think my aria is using band 40 can i make changes to the antenna to get a batter result or maybe im bot using it correctly ? i have a TOPLINK model : HW593Pro it hase 4 antennas and im usin the last one from the left side
finished most of the work i need my toolstik to solder properly maby ill finish tomorrow
okay thanks i will post the outcome once i finish ps im working next 2 days so i will finish in 3 days thanks again
hello sir thank you for your kindness im working this one for 1800 mhz my question is can i use 2 feed ? and about the isolation in Dv is it better with isolation or without
