streetdog
Everything posted by streetdog
  1. CST
    HELLO ALL , IM NEW TO ANTENNA DESIGN . IM DESIGNING A TRIANGLE ANTENNA WITH TRIANGLE GROUND AND PATCH WITH COAXIAL FEEDING ( HOLE FEEDING). MY QESTION IS I HAVE CONSTUCTED THE CONNECTOR BY WACHING SOME TUTORIALS AND NOW CAN I USE THIS THE NORMAL 50 OHM CONNECTOR WHICH IS AVAILBALE IN THE MARKET AFTER FABRICATION. AND HOW CAN I GENERATE THE GERBER FILES FOR THE FABRICATION . AND THE RESULTS I HAE ACHIVED IS 5.991 GHZ @ S11= -32.31 DB AND VSWR IS 1.049 AND GAIN OF 6.3DBI. IS THIS RESULTS ARE GOOD OR DO I NEED TO CHANGE ANYTHING? HOPE I GET THE SOLUTION THANKS.
  2. CST
    thanks can you clarify that is drill for the sma connector will comes in manfacturing or need to make it later? thanks
  3. CST
    can you please review my design once can you tell me what is wrong please
  4. CST
  5. CST
    i have attached the modified file. trianngle rt5880.cst
  6. CST
    i have modified now. trianngle rt5880.cst
  7. CST
    ho ok thanks , so i need to redesign it?
  8. CST
  9. CST
    , im using roggers RT5880 with thickness 0.787 mm and copper thickness is 0.035 mm and feeding location is x = -1.5 and y = 3.
  10. CST
    is power point means feeding point??
  11. CST
    hi , i have attached the picture with diamensions , yes from cst studio,sorrry unfortunately wrote with caps lock , next time i will write in normal letter.
