tardogblack
Everything posted by tardogblack
  1. 1. What factors affect the bandwidth, making it wider or narrower? 2. How is the feed point's distance from the center determined, and what effect does it have? 3. What is the reason for cutting the driven element? Why is it cut on one side or both sides, and why don't we use a full circular plate like the others? 4. Why 30 degree? 5. Can the rod be made from a non-conductive material like PVC or plastic? 6. What are your recommendations if I want to extend the antenna to 15 elements? Thank you if you reply this!
  2. Can you do at 1.42Ghz (Hydrogen line) Band Width atleast 100 Mhz, sir? I have some problem when I design its resonance at 1.42Ghz with BW=40Mhz Thank you so much
