rana75
4 Neutral
About rana75
  1. Do we have a batwing model on our website?
  2. I'm planning to use a double biquad instead of the simple one, to feed the grid, would that give any improvement?
  3. Can you tell me the max and the min depth of this 355?
  4. These are what I've got as an improvement, You can see the speed was increasing a little bit. I've been expecting something better, however this is the best I can do and get so far!
  5. Here is the built that I've just made. I attached the biquad into a PVC pipe, and I drew the coax from inside the pipe. The PVC pipe can slide inside the hole (see the 4th picture below). The last image showed the final work on its stand. I've got no measuring equipment or anything similar, but just relying on the windows stuffs. Tell me if there is something to adjust or to correct from my construction.
  6. Here is the biquad, with what I'm connecting to you right now. The design is based of the model from martybugs.net website. The refletor dimension is about 154mm*143mm, I did it according to what I have. Everything is still experimental, luckily working but unfortunately with a fairly poor result.
  7. Trevor Marshall suggested two sidelips (up and down) of 20mm, and Andrew McNeil suggested a 30mm one,which one is better?
  8. Hi Everyone, I've just built a biquad antenna and it's working fine now, I could reach a target at 500m from my home. However, I'd like to improve its performance, so I may get better internet signal and speed. I've got a 2 halves Parabolic Grid Reflector (approx. 100cm*60cm) but I have no idea, how and where to place the biquad, if I decide to use it as a feed for the grid! Thanks in advance,
