aurel
BatWing antenna 2.4 ghz
333 posts in this topic
It's true this antenna could cover  800 to 2700 ?
On 15/02/2020 at 3:31 PM, Admin said:
,,, and finally, the latest UWB batwing  antenna model is optimized...!!!
It's dielectric support or metallic support?
5 hours ago, Admin said:
,,,metal, M3 screw...!!!!
thanks jomy  .how  could i pass the  coax cable  ?
,,, something like that ...
 for cross polarization...
Hi
One question - what about distance between the centers of batwings and reflector size for MIMO?
And 50 or 75 Om cable?
TNX!:)
 ,,, coaxial cable with 50 Ohm impedance and a box with the dimensions below for MiMo Batwing antennas...
 ,,, an improvement of the Batwing antenna with dielectric lens...
,,, where do you see insulators at the wings of the box ... ???
,,, of course, you can't see ... !!! ???
3 hours ago, mr.ab said:
are these metal elements?
JOMY how  about the isolation (coupling) of 2 ports  in this  mimo antenna ? IS it good ?
 I think this connection between ports is not the right one....!!!
,,, a simple Batwing antenna made of thin sheet recovered from cans...!!!
,,,the *cst file...Pathe Batwing.cst
On 7/30/2020 at 8:26 PM, Sl4va said:
Made the first prototype
  Hide contents
Anyone had tested this SWR and gain? Thinking to make a dual polarized Bester feed out of this.
Edited by yeam
,,, a variant of cross polarization....
If you make it in a "bucket"? Will the gain be added?
,,,which one of them...???
,, a simple improvement of the antenna..!!
,,, a wider impedance adaptation band is obtained .. !!
,,,design...
Hi, what would happen to the antenna at batwing 2.4 if the size of the reflector make 78h130mm ?
I would like to insert 5.8 and 2.4 antennas into one case .
they INTERACT for the WORSE ! without simulation ...hard to know...
If the Batwing emits horizontally polarized radiation in the horizontal plane, then how to position the antenna vertically or horizontally with the slit, if it is transmitting, and there is a dipole at the reception, which is now vertical, can the receiving dipole be placed horizontally more correctly?
