acri
STUCK on CST
39 posts in this topic
Has anyone ever experienced something like this?
stuck on
calculating metrices: finished CAD processing
,,,stuck means that CST Progess has been blocked....??
,,,or stuck means " sticking "....??
stuck
cek this file
27.cst
3 minutes ago, acri said:
should s3 = s4?
I think so,,,
1 hour ago, Admin said:
I think so,,,
after I tried it, it didn't get results
the simulation process is stopped in "calculating metrices: finished CAD processing" loading but not running
", delete all the results and get it from the beginning...!!!
build start from ground again?
,,,try to check this tokens at simulator cst ...!!!
Acri, I'm fine for the file CST you sent to me, but the antenna is not well designed...!!!!
I understand my design is not good, but I will continue to fix it to get the best results in my opinion,
which makes me wonder why on my PC the process just stops there ... is it really the process that I posted that takes a long time ..
or my pc that is unable to process such a model
7 hours ago, Admin said:
,,, my friend, have fun with this....!!!
58.cst
New Folder.zip
is there nothing to change my brother?
I check it seems like there are no changes
What version do you use CST?
Edited by acri
"I have, like you, an old computer and an old program...!!!
then where is the difference? can it be processed on your PC while it stops on my PC?
,,,uninstall the CST with Revo Uninstaller and install it again....!!!!
ok brother i try it
