rob
yagi 2.4Ghz yagi
239 posts in this topic
1 hour ago, Admin said:
,,,you work with CST...???
I'm currently learning to draw and simulate disc antenna using CST software. Still new and learning. I still cannot find the formula to get the feed point / inset feed location. Some said it is about ~1/3 from the V or the radiator
On 25.01.2021 at 8:47 AM, Admin said:
,,,these are the real dimensions...
How much does the material of the antenna matter in this design? For example the difference between copper and steel or aluminum.
Edited by superolo
h0 = 2mm
,,, the material for the antenna does not matter, but it must be able to be welded...!!!
h0 = 2mm
Thanks!!
,,,a modification to Bester antenna...
,,,and even better...with truncated vibrator...!!!
Hello. Who has the correct drawing with dimensions for bdm 2400 mimo and 75 ohm cable?
i made one and it works really well ! What happens if the antenna is out in the rain? Will the water cause a short circuit and potentially damage my adapter (which I keep indoors) ? Or will it just not work properly ?
,,,papus... if the antenna is out in the rain, you have to protect the antenna with a plastic case...
,,,or so...
Beautiful ! Will do that B|
Thanks for sharing all this valuable information ! It is of great help
Edited by papus
75 ohm cable (for TV only), not for wireless(modem,antennas,etc) use...!!!
Кабель 75 Ом (только для телевизора), не для беспроводного использования (модемов, антенн и т. д.).!!!
Which one then? 50 ohm?
