noobbbb
Best Dish feader for 2.4Ghz and 5Ghz at one dish
Best Dish feader for 2.4Ghz and 5Ghz at one dish?
bester ×
dual band cantenna ×
bat wings ×
biquad ×
or something else ×
It depends on the DISH , F/D ratio  . offset or center feed...?
you'll be trying to achieve 70% efficiency (illumination) or more if possible.
I have couple offset . there is no center feed I thing. for the diameter I will check tomorrow.
Dish dimensions  99/80, depth 9.5 . feeder rod 59 . but the degree of the rod is bend. from the calculator I saw that have to be 17 degrees. So I will fit it in position.
Suggestions for feeders 2.4G and 5G?
Edited by noobbbb
thinking to make he can from copper since its going to be inside, soldering on the right dimensions should be fine
