checcoanz
dipole position 2600mhz
hello everyone I am doing the yagi uda DL6WU antenna at 2600mhz I would like to ask only if the dipole goes lower or higher in the boom or is it okay?. some time ago I created a 2,4ghz yagi and thanks to your dipole measurements it worked !!
Thank you. I wanted to kindly ask about things:
what is the difference between isolated and non-isolated boom ?. in the dipole it tells me that I have to use a metal wire of 0.4mm, if I use copper wire of 1.5mm it is not good?
Yes it is that. the only thing is that the diameter of the copper dipole is 0.4mm, I have 1.5mm in the house, can it be okay?
bigger diameter most of the times means wider bandwidth (wich is GOOD) some changes in impedance may occur (folded dipole won't change much) it's always 4 times that of a single dipole in free space 288ohm...(that's the reason why you need a BALUN 4:1 most of the times)
"The impedance of this antenna is around 300 Ω, so you may want to use a transformer or a λ/4 long piece of 120 Ω coaxial cable to match this impedance to 50 Ω. "
Use styrofoam to hold it (polystyrene FOAM , the lighter the better)
38 minuti fa, clanon ha detto:
diametro più grande la maggior parte delle volte significa larghezza di banda più ampia (è BUONA  ) è sempre 4 volte spazio libero quella di un singolo dipolo 288ohm ... ( questo è il motivo per cui hai bisogno di un BALUN 4:1 la maggior parte delle volte)
"L'impedenza di questa antenna è di circa 300, quindi poter voler utilizzare un trasformatore o un pezzo di cavo coassiale da 120 lungo λ/4 per abbinare questa impedenza a 50."
Usa il polistirolo per tenerlo (polistirene FOAM, più leggero è, meglio è)
ok I understand, now I will find a 0.4mm metal wire for the dipole and with the other elements I use 1.5mm copper wire
Edited by checcoanz
BANDWIDTH at 0.4mm diameter would be THIN (some Mhz) thin wire High Q Factor , small bandwidth
BANDWIDTH at 0.4mm diameter would be THIN (some Mhz) thin wire High Q Factor , small bandwidth ie what does it mean?
Il 8/9/2021 alle 16:11, checcoanz ha scritto:
On 8/9/2021 at 15:38, clanon said:
diametro più grande il più delle volte significa larghezza di banda più ampia (che è BUONA)  possono verificarsi alcuni cambiamenti di impedenza (il dipolo piegato non cambierà molto) è sempre 4 volte quella di un singolo dipolo nello spazio libero 288ohm ... (questo è il motivo per cui hai bisogno di un BALUN 4:1 la maggior parte delle volte)
"L'impedenza di questa antenna è di circa 300 , quindi potresti voler utilizzare un trasformatore o un pezzo di cavo coassiale da 120 lungo λ/4 per abbinare questa impedenza a 50 Ω."
if I do the dipole with 1.5mm copper with the same measurements is it okay or do I have to do it from 0.4mm?
