pragata.my.id
Tenda O3
CPU Processor  :  Broadcom 300MHz
Antenna Beamwidth  :  Horizontal: 60° Vertical: 30°
Waterproof Level  :  IP64
Remote Web access  :  Support
Schedule Reboot  : Support
Page Timeout : Support
Dyndns  :  noip, dyndns.org
Network Diagnoses  :  Ping, Traceroute, Signal Scan
Dimension  : 270*94.86*67.5mm
Frequency  :  2.4GHz
Maximum wireless speed  :  150Mbps
Maximum Transmit Power  :  800mw(29dbm)
Reception Sensitivity :  MCS0: -88dbm
                                 MCS7: -72dbm
Maximum Concurrent Clients  :  15
Interface  :  1*FE PoE/WAN/LAN port
                  1*FE LAN Port
Grounding Terminal  :  1*RST Button
3G Access
12dbi Directional Antenna
Maximum Power Consumption  :  6W
Lightning-proof  :  4KV
LED  :  PWR,Bridge,LAN,WAN/LAN
Power Supply  :  PoE Injector (12v 1A,Cat5e or Better Ethernet Cable Length > 60 meters)
Operating Mode
AP/Station/Universal Repeater/Repeater/P2MP/WISP/Router
Standard&Protocol
IEEE 802.11n/g/b
Features
Enable/Disable Wireless Radio
SSID Hidden
Wireless Client isolation
Sensitivity Threshold
WMM Capable
APSD Capable
Wireless Access Control
Wireless Client list
Security
64/128 WEP,WPA-PSK,WPA2-PSK,WPA&WPA2-PSK,WPA,WPA2
Transmit Power  :  Adjustable power by 1dBm
DHCP Server  :  Clients list
VPN Pass-through  :  PPTP,L2TP
Management Tool
Time&Date Setting
System Log
Firmware update
Backup/Restore Configuration
Username Managerment
Package Content
O3Power Adapter
PoE Injector
Ethernet cable
Quick Installation Guide
Temperature
Operating Temperature:-20℃ ~ 55
Storage Temperature:-40℃ ~ 70℃
Humidity
Operating Humidity:10%~90% non-condensing
Storage Humidity:10%~90% non-condensing
Default Settings
IP Address: 192.168.2.1
Login Username:admin
Login Password:admin
Certification  :  FCC/CE/RoHS
4 people like this
"Thanks Pragata, but some dimensions are needed at the adaptation lines...!!!!
and the distance between the patches...!!!
sorry, I forgot to measure it, this device is installed, maybe 2 or 3 days I finish the data.
but great, can carry bandwidth of 20 Mbps at a distance of 4 km, with horizontal polarization, signal -65dbi to -70dbi depending on conditions in the field.
okay and these are the results of my simulation with approximate dimensions...
for nice vertical polarization in the upper chanel, and for nice horizontal polarization in the bottom chanel, is that right?
hi all ... tenda o3 or ubnt nanostation loco M2. which is best as access point? loco M2 have 32mb ram but there is no data about tenda o3.
Tenda03----Antenna =12dbi
 ubnt nanostation loco M2 .... AntennaBuilt-in, 2x2 MIMO with dual polarization, gain of 7.4  to 8.2 dBi
Try adding reflector like the original design?
,,, this simulation is almost like the original ... !!!
On 2/1/2018 at 2:15 AM, Admin said:
can I get dimensional details of this model sir? thanks
1 hour ago, BurgHammer said:
Measurements are in the first post.
Well, it kind of not enough.
