jnkwqlqn
698-3800 Mhz Yagi
53 posts in this topic
,,, can you give some dimensions ... ??
,,, and what the vibrator looks like inside...???
Soon. I need to recieve the sample first.
Maybe you can create a BESTER feed out of this.
Edited by jnkwqlqn
,,, for testing this type of antenna, dimensions are required...!!!
,,,it can be the same....
,,,, and the F-dipole looks like this ...
Is this the actual design and dimension of the F-dipole of this antenna? May I know why two different Coax (RG-638 and RG-213 Coax) is used? Is this for impedance matching purposes?
Today i had received and tested the antenna. The results is not similar as stated
I see TWO resonances...one at 750Mhz and the other at 1500Mhz... and a third (weaker)at 1900mhz or so...
Yeam, can you post the dimensions to this antenna ... ??
I will post soon, but i think the manufacturer tested the antenna wth the 10 meter RG58 cable in roll (as shown on the photo in the first post), which means ghe manufacturer has wrong steps in testing the antenna.
23 minutes ago, yeam said:
I will post soon, but i think the manufacturer tested the antenna wth the 10 meter RG58 cable in roll (as shown on the photo in the first post), which means the manufacturer has wrong steps in testing the antenna.
16 hours ago, yeam said:
Here are the dimentions. Can you help me to simulate the s-parameter, radiation patern and gain? Thanks
Here are the s-paramter for the folded dipole itself only. It seem like having 4 different working frequency. So bad 2.6Ghz is missing which is a common LTE frequency
,,, yeam,, thank you for your post,but you can give the dimensions more clearly because it is not distinguished on your images..!!!
,,, these dimensions are good(in mm) ... ???
Clanon,,,, good job, but I don't know if you respected the F-dipole connection...!!!
you're RIGHT ...i was tweaking and fiddling with it...trying to get the  S11 right....(closer to the measurements...)
i think that the cylinder thing helps widen the band...and NOT sure about the port distance (dipole gap)
dont forget the IMPEDANCE MATCH with 125ohms quarter wave...
i think i'm close...2.3ghz is not showing REMEMBER to use a 300 ohms port
yagi.cst
Hi, the dimensions you shown above are correct
