biged147
flower pot antenna
I need some help with this antenna see I live in the USA and we don't that size ECPVC pipe or PVC pipe of that size here is the sizes
1/2 inch which is 0.840 or 21.336mm both type pipe
3/4"  od 1.050  26.67mm
1"  1.315 od  33.401
Would the 3/4" pvc pipe is as closed as we can come to in the  USA, is there  any different in the dimensions the one I trying to build is
Experimental Dual Band High Gain Flower Pot Antenna
it's a 1" OD (2,54mm exterior) conduit for electric cables...PVC...(Really THIN WALL)
any PIPE would DO
The LESS plastic the BETTER
i think on 3/4...check the MATH...
Diameter x Pi = length (perimeter)
No worries guys.... it seems its not a Flower Pot snake, but rather a Delandes beaked blind snake - Rhinotyphlops lalandei... Still a nice little find none the less..
I already posed a question about this antenna, I made some simulations, have you succeded to simulate it?
Where can you get a 25K audio taper pot for the mid control, other than Alpha? Cant seem to find one in CTS, and CGEs offerings are diminished as well.
Thanks
