roman55524
simple antenna LTE MIMO 1800 MHz (for satellite dish)
I suggest testing the design of this antenna. Jomy, I ask you to simulate the antenna.
Impedance-50 Om
Gain-9 dBi
6 minutes ago, roman55524 said:
error in reflector size ( 130mm
,,,EEEEE>>>
What can you say about the amplification on the edges of the LTE 1800 range in Russia? I have an assumption that this antenna has a bad outcome between ports.
With this type of MiMo antenna there is no isolation between ports..!!!
Than it is bad? Isolation between ports is available only for systems consisting of two antennas, each of which operates in a separate polarization
9 minutes ago, roman55524 said:
layout for carving
mimo1800.vsdx
I can not open vsdx.file, it does to put a different file...!!!
I did not install MS Visio..!!!
,,but what do you want to look at with this  file...?
print on the printer, paste on sheet iron and cut
