Ghost
Antenna panel
Same shit...on metal (more efficient , less losses, BETTER)
thanks but it's too complicated for me, I want to use an antenna for outdoor, maybe there is an easier model. the distance
+ - 500 m.
does it have to be MIMO...?
hardware...on the Receiver side...?
500mts , anything over 10 dbi (directional) would do...
i will use tenda n301 for the Receiver . are this antenna will work , this antenna I have found the size
c834e11bac56db36bc98e5089747e3d0.jpg.03f
after being calculated on google maps the distance is only 200m
Two identical  antennas , separated ...would ALWAYS be better than one with small ISOLATION between ports...
Polarization (Lineal , Horizontal or Vertical ; Circular LH or RH) should be the SAME in Receiver and Emitter
