Kledi
What Is this antenna?
Hi, can someone explain me what Is the "short-pin" on this antenna?
short pin here = piece of conductor(short-circuit conductor)
It's for unbalanced LINES (COAX) NO need to use a balun... (PS: Since the antenna GEOMETRY is electrically "BALANCED")
8 hours ago, Kledi said:
Can this antenna work into a dish?
,, it is possible, but it is quite complicated to build...!!!
Their are No Magic Antennas , no mater what the manufactures claim.
It is a Cheap China antenna.
Cheap plastic.
Cheap soft aluminum.
Metal parts that corrode easy.
I did not know where to post this so i ended up here. I have been trying to figure what this part is . It has an inside dimension of 1- 7/16 Can anyone help?
Is called a SHORT pin ..cause it does that... SHORTcircuits the antenna... to GND
A balanced feeding structure, shown in Figure 1, consists of two shorting pins and two feeding coax cables. The two coax lines are placed along the centerline of the radiating patch and are located at a distance of S/2 from the center of the patch. The outer part of the feeding coax cable is connected to one arm of the dipole (yellow circle in Figure 1) and the inner part connected to the other arm of the dipole (red circle in Figure 1). With two shorting pins connecting to the inner part of the feeding coax, good isolation between the two ports is achieved.
