Antenna DVB-T2 TV REMO panel (Squirrel)
Antennas work and perform their functions, there is a noticeable difference in price, although it should probably be the other way around !
Do not forget that for confident reception of DVB-T2 at a significant distance (60-70 km )from the signal source, it is necessary to raise the antenna from the ground by 12-15 meters, a strong mast + MANDATORY GROUNDING + side lightning protection.
Source DVB-T2 Ostankino 10kW — distance 20 km conditionally direct visibility of the floor 12.
