the K3TZ AntennaOptimized Design
Ultimately, when the K3TZ design was tested, the ease of construction and consistency of results demonstrated the worth of this antenna.
That is why when I actually found a design, I decided to learn as much as I could about it. I found some patch antenna that will allow you to design and simulate a patch antenna and entered this design.
the Axial Ratio,,,
By applying a cut in the patch, increase the bandwidth width and uniformize the impedance
This is the simulation on the original antenna
not bad, :D...  I see there is a 10% increase for signal quality.. thank.
Yes, but on PCB needs other dimensions ... !!!
saya tidak mengerti apa jenis PCB ini .. :D which is definitely not fiber.
Edited by pragata.my.id
,,,for pragata.my.id K3TZ on PCB...
Can i use thick galvanized steel ac reflector, thickness about 0.3 mm? , and any changes for 100mm x 100mm reflector?. Thanks a lot.
Edited by alhaba.production
Need some question to be aswered.
,,no, for this you need other dimensions...!!!
,,see the first post...!!!
