Cathairez
ATT Fixed Wirless boost
I looked around trying to find a forum for antennas, networking, etc., and this seemed to fit the bill. I have ATT fixed wireless, it's LTE band 30 at 2300mhz. My RSRP is typically between -112 and -119 (-120 is the cutoff for installing it). They promise 10mbps DL and 1mbps up, MINIMUM. I typically get 2-3mbps down and 300kbps - 500kbps up. At times it drops so slow it takes several minutes to load a website. The tech told me there was nothing he could do to get me those speeds.
I was wondering if there might be some way to boost or amplify the signal and rebroadcast it near the antenna ATT installed. It's a model #OWAR0-35.  There's really nothing else in my area besides satellite (and I don't want that AGAIN). I found antennas for the 2300mhz frequency, I found amplifiers, but the antenna from ATT only has one port for an RJ45 that runs to an "antenna box" and then to the modem/router itself.
Your Reference Signals Received Power (RSRP) it"s verry poor...!!!
,,, what does this antenna look like inside...????
