Sector Antenna 2,442GHz
87 posts in this topic
On 1/21/2020 at 2:47 PM, Admin said:
Raul, if you have such an antenna, you can post a few details and dimensions ... ???
Design of Coil antenna
Coil inner diameter: 6 mm
Number of turns: 7 turn
Wire Diameter: 1 mm
Spacing between turns: 3 mm
Admin can you simulate this design in CST? I think this design is match to the wave vibration.
Total oouter diameter of circle: 61.999 mm
Wire lenght : 747.687 mm
Raul, this sector antenna is very interesting, if you have one, I would be interested in more details and dimensions....!!!
Ok admin. I will make detail. Wait..
If one line charged can give 9 dBi i think every additional one charged can give 3dBi power. If we put five or seven charged maybe can make upto 45 dBi
,, I would like to see the connection lines between spirals and dimensions >>> !!!!
each unit 9 db
2 of those 12 dbi max
4 of those 15 dbi max
8 of those 18 dbi max
Under IDEAL conditions...(feed network. dielectric losses , mismatch etc)
up to  20 ...22...24 dbi is achievable on 2.4ghz (over a 1 meter area at 24dbi)...more than that is BALONEY...Bullshit...never seen...never happen
On 5/9/2020 at 10:33 PM, clanon said:
each unit 9 db
No i mean not that.
Above is bad antenna. Very high vswr
I wonder, is it possible to reduce the back reflector width to 120mm, and how bad is the impact if I do so.
,,, try it, but don't post so many pictures...!!!!
,,, at the request of the user "Curb S. Gutter", I tried to optimize this antenna for a wider frequency band...
