akoneko47
Omni 15dbi outdoor
I'm beginner for antenna
I have ordered Omni 15dbi outdoor and they sent the product is in an incomplete condition. (The center axis of that pole slipped inside )
I try fix tem but i saw "The two poles are linked together"
And I want to know this is the right thing And it works normally ?
The two poles (line +, line -) are linked together
it works normally ?
Edited by akoneko47
,,,you can give the dimensions of this omni antenna...???
,,,for which the frequency works..???
No, I would like all the dimensions for the whole antenna..!!
I think the antenna is correctly built but only the connection socket is not OK. Better to return the product...!!!
", that's how it should look ...
Oh! sorry for unit of measure
and If it just has a problem at the socket, I can fix it by myself.
Thank a alot @Admin
After this I will seriously study the antenna.
10 hours ago, Khubaib said:
Hi, can i have complete design of this antenna?
That might be close to reality....
