Gray Hoverman Antenna
This project is dedicated to Doyt R. Hoverman (b.1913), the man who created and did the early work on the Hoverman antenna at a time when antenna modeling programs did not exist. His work would have been entirely created and improved by field testing, trial and error, and with a great amount of calculation without the benefit of electronic devices. Without his efforts, our work would not have been. Doyt Hoverman passed away in December, 1989 at Van Wert, Ohio, USA.
Technical data
Simulation
With insulating spacers
For the impedance adaptation (300 Ohm> 50 Ohm or 75 Ohm) the following variants can be used:
on PCB #1,5mm
And a practical realization of the antenna...
great  ! JOMY can you simulate it for 1800 lte  ?   its simple  and gives high gain
,,,okay,I will try...!!!
On 21/04/2017 at 2:47 PM, Admin said:
Hi can I use gray hoverman antenna without impedance
I don't understand exactly what you mean...!!!
I mean can I use the Gray hoverman antenna  as wifi antenna without impedance I mean omit the impedancepcb-balun1.jpg.92ae2030b5a820d2e31e5271a6f69995.jpg IMG_4378.thumb.jpg.8f9d4fb1e57b5e61d2ff5dffd0e62399.jpg
,,,why don't you read this post carefully,,,?
