matek_24
Ubiquiti NanoStation M2
,,,hi buddy ...!!!
,,, if you did the simulation with CST, why not post the * cst file
The main problem is I don't know how to do that.
1. What do you mean "translated"? moved, transfered? why?
2. reflector made of what material?
3. pcb thickness is 1.5mm
4. I guess a bit bigger then antena
Do you have any tutorials? I just started with antenas and CST.
,,,my friend, please follow this post...
Something like that...
I'm trying to go throght this topic. It's not so easy but I can do it :-)  Your antenna looks exacly how I imagined it
30 minutes ago, Admin said:
", and yet, what are these dimensions...???
I have no idea of these dimensions, because I've put the picture into Inventor and I copied all of edges except these - sized
Sorry, it's not my antenna, it's yours ... !!
,,and how do you copied the antenna with inventors...??
,,, and do you think that  the dimensions are the real ones?
I'm sure they aren't but I found only these pictures on internet. I needed something to start with.
Could you send me *.cst file what you've made, please?
1 minute ago, Admin said:
,,, in fact, my * cst file is yours...!!!
So, can you send me a MY .cst file?? ... with yours changes :)
Hi, when I try to import the file to HFSS this error appears:
  Ubiquiti (DrivenModal)
    [error] Acis error: "Fail to restore entity list.. Acis Error 63005 - save file is from a later version of Acis " (6:49:34 PM  Aug 29, 2023)
    [error] Import Native Bodies: Translation of "C:/Users/MyPC/Downloads/ns2.sab" failed. (6:49:34 PM  Aug 29, 2023)
Edited by Carrasco2001
